38-10 photo finish touchup
I am restoring a 38-10 "Bullet" which has a scuff in the Photo finish on the front panel. The rest of the cabinet is fairly good; any suggestions for touching it up?
Tim KA3JRT
Hello Tim. This may help some. Take care, - Gary
https://philcoradio.com/phorum/showthrea...ish+repair
Ok guys. Thanks for the input. As for AI this is why I ask the experts. Dandconant — 07:39 AM
Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM
hello Roy, I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM
This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM
Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM
