PT42-87
This has a leatherette cover. I’m assuming I start with warm water and soap for cleaning followed by mineral spirits?? Is there a source for replacement cloth,
It looks like a smooth brown leatherette not a textured leather like on the pt-87
Hello Bridkarl,
You might try Ampified Parts here is their link
Ampified parts
I would start with wiping it down with a wet cloth then use the GOOP hand cleaner to remove the tough stuff. If the covering is not too badly damaged you may get by with cutting patches from the wrap around on the inside of the cabinet.
Boy, I've seen some sad tenite escutcheons lately.
Ok guys. Thanks for the input. As for AI this is why I ask the experts. Dandconant — 07:39 AM
Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM
hello Roy, I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM
This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM
Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM
