Whos familiar with Telechron movements
I had to disassemble a clock assembly to replace a broken gear and now when I get it back together I cannot get the radio/alarm/off/radio arm  shaft to stay on radio . Every time I turn it to the radio position it snaps back to the off position. It stays just fine in the radio/alarm position.
Hello Jim,
What make and model is the radio also have you troubleshooted the switch on the clock that turns the outlet on and off I have had to replace it .
You could try telechronclock.com. They were helpful when I restored a Crosley clock radio.
I used a guy from eBay. For $50 he took apart, cleaned and re-assembled the whole thing.
Works like a charm.
The clock is out of a Zenith L520. When I first tested it the switch for the radio alarm/off/radio worked just fine. I had to disassemble the mechanism in order to replace a broken gear. I finally got it back together and the clock works just fine. Its just that when I turn the switch to radio it snaps right bac k to the off position.
RodB, I didn't know there was telechron  forum. Thank you for the heads up on that and I will visit them for some help.
Hello Jim,
Yes, If I was home not in this rehab center I would get my Telechron parts diagram for this radios clock movement.
Sorry for this late update. I bought another assembly to use for the motor and when I went to reassemble the it I put in the wrong shaft pieces. With the correct ones installed I have a working clock assembly.
