11-12-2025, 09:16 PM
Hi All. As the subject says, I'm working on a 42-380 that is very quiet. I've replaced all caps and some out of spec resisters. Powered it up and got nothing. Check voltages and with my variac at 112 volts all voltages are right on the money. All the tubes have been tested and are good. I did have to sub the XXLs with a 7A4 and a 7B4 which pretty much the same thing. It is oscillating. I checked it with another radio.
I noticed that on the schematic the antenna coil, it says is from point 1 to point 4 should be 150 ohms. My antenna coil only measures 4.5 ohms. Is the schematic wrong or do I have the wrong antenna coil. It looked original. I even took all 3 IF cans apart and checked everything inside them and changed 1 resister in the third IF can.
So my question is, has anyone experienced this problem and does anyone have any suggestions as to my next move to get this thing running.
Thanks for any consideration,
Dick
Dick
