Kyoritsu a.c. clamp meter model 830
Threads: 33
City: Kaiapoi New Zealand
Hi everyone . I bought yesterday this meter - for $5! It has an ohms function which works and it has a volts function which works.It does not have an operating manual nor does there seem to be one on the internet . And sadly the current function , which was the main reason for buying it seems not to work .I am not sure whether , on current function the power cable can just be encircled by the jaws or whether the jaws must actually be opened and , on release actually pinch the cable like a pair of pliers.If anyone has had experience with this meter and can offer any ideas on how to operate it on current function correctly or if they are familiar with it seeming not to work measuring current I'd be grateful to hear. Thanks everyone and cheers.
Threads: 9
City: Roanoke
The clamp should encircle just one conductor of the cable. The jaws must be closed when making the measurement.
as Dale has noticed, with some explanation:
The clamp is the core, making a current transformer.
It has to clamp around ONLY ONE wire (not, for example, the whole AC cable, as summary current will then measure Zero Amps). This one wire is the Primary winding of that transformer.
Inside the meter is the second winding, a milty-turn with Ohmic low-value load.
This is where the Voltage measured across that load as the proportional value to the current in the wire through the clamp. Then it is calibrated to show the Amps.
This is for the AC component.
If the clamp is DC-capable, the DC is measured by a Hall element.
In order for the transformer to work (that is the flux to circulate in the core) the clamp has to be closed. Else there is no core, no flux and no measurement.
Threads: 9
City: Roanoke
morzh Wrote: as Dale has noticed, with some explanation:
Thank you for providing that explanation. As I get older I tend to provide minimal explanations, when some members would benefit from a more expansive explanation.
(This post was last modified: 11-16-2025, 07:20 PM by DaleHCook.)
My knees recently and my back (started at the same time, about a few months ago) persistently remind me that I ain't getting any younger either.
Threads: 33
Thank you fellows ! Great result !I have made up an adapter from a piece of three core cable, separating the 3 insulated cables so that the jaws of the meter can go round just one active one. I plugged in a two bar electric heater to the adapter and measured the current - 5 amps with one bar turned on . Exactly as it should be . And thanks to your generous explanations I have learned how it works. Thank you all.
Threads: 9
City: Roanoke
morzh Wrote: My knees recently and my back (started at the same time, about a few months ago) persistently remind me that I ain't getting any younger either.
With me it's my knees, my back, and my right hip (which, if I live much longer, will need a replacement). All of those began bothering me about five years ago. I have been through enough illness this century (some of which would likely have killed me in the early 1900s) that I consider myself fortunate to be in somewhat decrepit but otherwise healthy condition.
Threads: 437
City: Boston
Phorum is the only place I know where we discuss renovating old electronics as well as old electronic renovators bodies! Good luck with both aspects of our hobby!  Paul (a recent knee replacement Antique Radio Enthusiast)
Threads: 41
City: Wellborn Florida
You said active wire just to make sure. The wire the clamp goes around would be the one going to the breaker. Hope you are enjoying summer. David
Threads: 41
Dale
While i knew I had herniated discs (accidental discovery during an unrelated reasoned CT Scan some 6 years ago), none of it bothered me.
All started at my mom's place. Stress, then sleeping in a bed with a very different mattress. Both the knees and the back.
It's been 4 or so months since I came back, but the trouble stayed. Plus more.
Oh well...at least, when I wake up, I know I am alive.
| Ok guys. Thanks for the input. As for AI this is why I ask the experts.
Dandconant — 07:39 AM |
| Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM |
| hello Roy,
I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM |
| This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM |
| Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM |
| Roy;
Personally I would have left the asbestos alone if it were my set, but you can find a modern substitute that som...Arran — 04:51 PM |
| Looks like that might be the B- buss, so that would be correct.RodB — 01:32 PM |
| I noticed on the code 121 schematic the center tap for the 6 volt winding and hv winding are tied together. Is this corr...dconant — 12:16 PM |
| The Philco Parts Catalog for 1942 shows it as usable for 175 kHz, 260 kHz, and 465 kHz. The instructions will show how t...DaleHCook — 11:19 AM |
| Hello Rob,
I agree with you—I have one here at my house that I need to check out. It’s way over-engineered just to make...radiorich — 11:05 AM |
There are currently 2895 online users. [Complete List] » 2 Member(s) | 2893 Guest(s)
