12-01-2025, 04:13 PM
https://philcoradio.com/library/download...20222A.pdf
I have a Philco 116X and although it’s probably too complicated for me, it was free so I will do my best.
I’m working on Part #83, a 4 section electrolytic, which was missing from the radio when I was given it. I could figure out where the 1 mfd cap that comes from the 77 1st audio tube, black arrow on the photo, but not the other three caps.
The attached photo shows my 30K resistor attached to pin 3 of the 77 tube and the 10K attached to pin 2 of the 76 tube. They are then attached to different lugs on bakelite block Part #44. That terminal strip was added at sometime, with #99 a 13K resistor and #98 connected together. Is this correct? I cannot trace how #97, the 30K connects to #98.
Also I can’t find the 10K resistor that the other black arrow is pointing too on the radio. The number they have assigned to it, either #101 or #104, doesn’t correspond to anything on the parts list.
I can’t follow schematics well yet and I have trouble explaining what I need to know but I would appreciate any and all advice on how to connect the other caps of Part #83.
