New member with a couple unusual Philco radios
Been around the 'net since '87, but just joined this board. Anyway, I have a couple of unusual Philcos, one from New Zealand, and another from Peru.
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
Welcome! Icon_smile
Two very cool Philcos you have there. I just bought a 46-806. I've seen many photos of the NZ Philco sets but never have seen one "live and in person."
The 46-806 is identical in appearance to the 42-706. I used to have an A-707, which is a 42-706 chassis in a 42-PT3 cabinet. One of the sets I should have kept.
Hi Robert. Long time no see.
-Bill (exray)
Cool. I have used the WA2ISE submini tube reference page plenty of times.
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
There are currently 1002 online users. [Complete List]
» 3 Member(s) | 999 Guest(s)
