08-31-2026, 06:14 PM
I would like to remove the three square cans from my 630 for cleaning but I can't get those clips loose. Any have any clues how to do that?
Thank you,
Dan
Thank you,
Dan
Remove IF Cans
Thank you, Dan
08-31-2026, 06:33 PM
Here's a photo of one. They snap into the slot. Pinch the tab to remove.
08-31-2026, 06:55 PM
I tried that but the needle nose always slips off. Ah maybe try small channel locks. Seems to work but really have to squeeze. That worked for one. Now I have two where I can't get the pliers or needle nose in there.
08-31-2026, 10:17 PM
I seem to remember pinching the tabs from below.
09-01-2026, 01:47 AM
Try a small nut driver, one where the socket end will fit over the pointed part, barring that try a piece of metal tubing.
Regards Arran
09-01-2026, 07:45 AM
Ah yes Arran that sounds like a good idea.
09-01-2026, 04:23 PM
You should try squeezing from the top of the chassis. Look at the mechanism, it was made to pinch from the top.
09-03-2026, 08:28 AM
I got the cans off by using both methods. Some you can't get from the top as other stuff is in the way so a small socket did the trick.
« Next Oldest | Next Newest »
Users browsing this thread: 1 Guest(s) |
