42-355T - wring rubber or not?
Is the wiring in the 42-355T rubber? I saw one yesterday, but I may not be able tor emove the chassis to check before deciding if I want to buy it.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Yes, it is.
All Philco sets made in the USA between 1939 (June 1938) and 1942 have rubber-covered wiring inside.
Just a FWIW here even though this does not apply to a 42-355, but most 1939 models even have rubber-covered wiring coming out of the power transformers.
Thanks. I've found one, along with something else I want in a shop, and will use that fact to get it cheap, or pass on it.
Well, good luck to you. Icon_smile
I mentioned the rubber-covered wiring being used in USA-made Philcos between 1939 and 1942, because I have a Canadian Philco 39-330AT which looks just like a USA Philco 39-25T but has a chassis similar to a 39-30T. One major difference - it has six pushbuttons instead of eight in the USA models. Also, all of the wiring under the chassis, with the exception of the two IF transformers, is cloth-covered wire. Only the wires from the IF cans had the dreaded rubber insulation. That made this set much easier to restore.
462ron
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
There are currently 453 online users. [Complete List]
» 2 Member(s) | 451 Guest(s)
