New Acqusition Philco 21
Well the bug finally bit.(kind of a funny expression for me to use as I been diagnosed with chronic Lyme disease ten years ago) I've been looking to get a cathedral set and have been chasing a few model 80's and 84's but prices haven't been quite what was willing to pay. Till this model 21 came up. Price was good and it looked pretty restoreable. So I pulled the trigger and bought it. It was local so with a 20 minute drive I had in hot little hands.
All in all it is in pretty good shape but after doing some checking found that the three rf coils are open primary and secondary, audio driver transformer, primary open BC resistor, one section open field coil, open. I'm a little afraid to measure the power transformer. Chassis is dirty but very little rust. Mershun cap has been replaced along with the filter that is under chassis.No metal box for the under chassis cap. No tube shield but I heard that Dick Oliver Is making repros of them. Speaking of repros I'm also going to get the front panel, arch, and molding.
The above is not a complaint but some sets can run into a lot of time and dead presidents to get them back to good or better condition. I'm very thankful that there are guys out there like Dick Oliver and many others that make some restoration much simpler.
When I picked the set up I told them I'd have it working that night, That didn't happen!
Will post some pics on my Flicker page soon.
[Image: http://farm6.staticflickr.com/5257/54665...4a97_b.jpg]
Philco Model 21 by TBS-50B, on Flickr
More Pic's Here: http://www.flickr.com/photos/53710524@N06/
Congratulations on your acquisition.
Is that the one that was on eBay?
Oh, and do you have it going yet? Icon_lol
Doing a resto on a "basket case" can actually be more fun than trying to restore somthing in better shape. Especially if it is a relatively hard to find set like your model 21. There is less pressure to make it "perfect," and more pleasure in making it much better than it was when you aquired it.
Additionally on the "basket cases" that I have brought back to life, I have learned somthing about circuitry and replacement, and even cabinet work, that I haver put to good use with subsequent restoration projects.
It would be interesting to follow your progress on this neat set, maybe some updates and photos??
Yeah that's the one from epay. Haven't got it up and running as it needs a bunch of work. Anybody rewound a field coil from a K type speaker? What size wire? and how many pounds will I need? I did a quick measurement from the grid caps to ground and from B+ to the plate pins of the 24'A tubes all measured open. Is the coil winding data around?
All I've done so far is just a few measurement and a general cleaning. Thought I might pull the 80 and fire it up to see what filament voltage I have on the output tube sockets. Seems like I could have 5.0v if it's an early job and I wouldn't want to waste a good pair of 45's if it doesn't have the required 2.5v.
Will keep you posted.
I'm surprised that all three RF coils would be open, this warrants further investigation. The audio interstage burning out is a common problem with sets from this era but not an open speaker field coil, those rarely burn out unless there is a shorted output filter capacitor. You may find in each instance that the problem is something as simple as a bad solder joint or a wore broken away from the terminal.
Best Regards
I'm suspecting corrosion more than anything from moisture and acids in the paper/other materials used in construction.
Not too much at all! :lol:  Sounds like you’re just dabbling into the hobby!jrblasde — 07:56 AM
Hi Joseph, Fortunately, Ms. Fixr does not read my computer, or she would warn you against coming to me for sanity ch...MrFixr55 — 07:27 AM
48-482 rear panel help
There's a picture of one of the plastic covers in the following thread: I bought a full set of them in 2012 or so fro...klondike98 — 11:15 PM
Good sanity check! You are correct—the first (as in, the most counterclockwise) position is for the push button presets....jrblasde — 11:05 PM
Hi Joseph, First, verify that your band selector is in the correct position for what you want to do. I believe tha...MrFixr55 — 10:59 PM
Got my replacement signal generator in the mail today! I was able to finish alignment of the IF section. I’ve got some t...jrblasde — 09:58 PM
EdHolland. Glad you liked it. Thanks for the supportRadioSvit — 05:24 PM
Great stuff, Peter thank you for posting.EdHolland — 04:06 PM
My Philco 37-116 Restore
The crack goes from almost the bottom of the tube to well past the fat part. It is an ST type tube. The filament is open...dconant — 10:04 AM
Where is the crack? A cracked tube that has air inside will turn opaque once turned on. Perhaps it is a scratch, nogt a...morzh — 09:50 AM
There are currently 302 online users. [Complete List]
» 1 Member(s) | 301 Guest(s)
