What did I buy?
http://cgi.ebay.com/130495289420
Can anybody tell me if it is a model 60MB or a 66B? Had a model 60MB years ago.
Tnx!
Impossible to tell from the photos. Good luck stripping the brown paint from that thing.
I thought that would be the answer. Couldn't be worst that that model 20 cabinet!!!
Tnx
Terry Hoping for a 66B
The shortwave dial on a 66 goes to 16.0 MHz, the 60 only goes to 4.0 MHz
Yeah I'm hoping it the 66 as it does better SW coverage. I've the 60 in a cathedral cabinet.
Hooray!!!!! It's a model 66B. Everything looks good but the dial escutcheon is worn off sanded maybe? Should be a fun project to get going again and cruise the SW band!
ps anybody got an escutcheon for 60mb or 66b?
Rogers Majestic R-646
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 970 online users. [Complete List]
» 4 Member(s) | 966 Guest(s)
AvatarAvatarAvatarAvatar
