Volume won't go completely down
Hi,
I bought a Philco 84B that had no volume control, the sound would not go up or down. I found that the antenna transformer primary was open. I had the transformer rewound, now the volume goes up and down but not completely down. There is always sound coming from the radio even when the volume control is at the minimum. Any thoughts?
Sound out of a radiio iis always a good sign. Perhaps he On/off switch is shorted. I wish they were all that easy.
In model 84, the volume control is between the antenna terminal and ground. If the radio is not grounded, the volume won't turn all the way down. So...you need to connect the GND terminal to a good ground.
Please note that even if grounded, you still may not be able to turn the volume down completely on strong local stations.
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
There are currently 858 online users. [Complete List]
» 1 Member(s) | 857 Guest(s)
