Repair of on/off switch for 42-321
The on/off switch on this radio is not working. Can these switches be repaired? The volume control part of the switch is good.
Does it click when you turn it?
Yes, it has a good solid click when turned on and off.
Bob
Well unsolder it and carefully pry up the tabs that hold on the cover. Once you get the cover off spray the innards with DeOxit. Try this for starters and see if that does it. If not you can drill out the rivets that holds the switch to the cover. After you get it apart use a lite abrasive to clean up the switch contacts.Get some small screws from the hobby shop to put it back together. You may find the contacts are badly burnt that's time to find a new pot/sw.
Good Luck/w it
462ron
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
There are currently 453 online users. [Complete List]
» 2 Member(s) | 451 Guest(s)
