Permanent Magnet as a Philco Replacement Speaker?
I recently acquired a Philco model 38-5 tombstone that is missing the speaker. I have placed requests in the "Wanted" sections of various radio sites but have come up empty. As a temporary solution I would like to install a permanent magnet speaker until I someday find an original. While I've restored a quite a few radios in my time I have never had to replace an electrodynamic speaker with a permanent magnet type and am unsure how to proceed.
I'm missing:
- the output transformer
- the field coil
(are the output transformer and the field coil the same thing?)
- the voice coil
I've done some searching and it sounds like using a choke of the appropriate rating is preferred to using a resistor and bumping up the capacity of the filters when replacing the field coil so I'd like to go that route.
In the absence of the original speaker how can I determine what the voice coil resistance is?
I'm not even sure how to begin Icon_redface. Any advice would be appreciated.
Geoff
The Model 38-5 used two speakers, one in the table top, or B cabinet and another in the console, or X cabinet.
The B cabinet uses a Model H-29 speaker.
The X cabinet uses a Model K-39 speaker.
Both speakers have the same field coil which has a D.C.
resistance of 660 ohms. Both also have the same voice
coil impedance of approximately 2 ohms at 400 Hz.
A PM speaker of 4-8 ohms should work just fine however.
A replacement power resistor to sub for the field coil can
be a 680 ohm, 10 watt unit to run cool.
This is assuming a max current of 90 mA.
Alternatively, you could starts looking for a H-29 or K-39 to fill the bill.
The Model 38-3 and 38-4 also used the H-29 speaker.
Thanks for the info Chuck. I posted the same question elsewhere and got some good follow up:
http://antiqueradios.com/forums/Forum11/...07746.html
I also noticed in the schematic that the 38-4 console uses the same chassis with an H 29 speaker (my table top model 38-5 uses the K 39). There is an H 29 speaker on eBay right now but at 11" I think it would be too big for the table top model. And from the description it sounds like it has been modified:
http://cgi.ebay.com/6619460062
There is also this H 21 speaker but I'm not sure if this would work for my application:
http://cgi.ebay.com/6619301772
Regards,
Geoff
Yes, that's the differeence between the two speakers, just the size; smaller one in the table-top cabinet, but with same electrical specs.
There are currently 1089 online users. [Complete List]
» 1 Member(s) | 1088 Guest(s)
