Philco PT-25 tube layout
I need to know the tube layout of the radio for a PT-25. I have the tubes but they were not in their sockets when I got the radio. I think I have figured out where they go but would love to know the layout to double check my analysis. Thanks so much.
[Image: http://i326.photobucket.com/albums/k420/..._tubes.jpg]
This is the tube layout for most of the TH-, TP- and several of the PT- series Philco Transitone home radios.
Thanks Ron. This is exactly what I needed.
Hi Gary & Welcome!
I see this is your first time here. Great bunch if you need help or info for your Philco.
Here's the diagram for your PT-25 It's actually for the TH-4 but should be the same or pretty close. http://www.nostalgiaair.org/Resources/241/M0014241.htm
Gud lk w/it
Terry N3GTE
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
Meter is a DMM (Brymen BM-257 to be exact) Voltage being measured to the chassis Yep, just double-checked 'emsq65 — 10:22 AM
