Philco 90 question
Hi all,
I am, after many years of looking, the proud owner of a Philco 90 baby grand! I have wanted this set since I was a freshman in high school, but have never found one that I could afford. The ones I've seen that I could afford were past any help I could give it. I finally found a good restorable one on Ebay for $200 bucks! I want to do the best restoration I possibly can on it. The cabinet is in good shape as is the chassis. However there are several areas on the chassis with a fair amount of rust on it. I want to clean off the rust and my question is. What is the correct finish for the chassis? Were they plated with something? The chassis on the two 70's I have are a dull lead gray color, was this the color when new or were they shiny? Is it acceptable to paint the chassis? If so, is there a paint/color that closely approximates the original finish?
I guess I just want to do what is considered correct, so any input would be greatly appreciated. Thanks!
Kevin
Only my opinion, but the early sets chassis almost look like they were a parkerized finish, similar to what you would see on some military weapons.
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
Meter is a DMM (Brymen BM-257 to be exact) Voltage being measured to the chassis Yep, just double-checked 'emsq65 — 10:22 AM
