Model 39B
Hi To all,
After braving a typical spring day in Wisconsin. I.E. rain, 50 degrees and 35 mph winds! I found this Model 39 cathedral at a flea market. I'm not much into battery sets, but this one was exceptional! Rust free chassis with original battery tag still attached! Even has two Burgess 'C' batteries connected to the cable. Upon closer inspection, apart from tubes, I don't think it has ever been serviced. Probably paid more than I should have, but for some reason, I couldn't pass it up.
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
Great find! Icon_thumbup Looks like it is in pretty nice shape, also.
Nice! That is essentially a DC powered model 66. You have a fairly broad shortwave band on that set. Definitely a keeper!!
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
There are currently 783 online users. [Complete List]
» 1 Member(s) | 782 Guest(s)
