Philco model 76 lowboy
Have aquired an old model 76 lowboy that I want to restore,and was told that I should re-cap and install a fuse.
Anyone have diagrams as far as where the fuse should be spliced in?
I was told on the center tap(B+)and the wire to the number 280(80) tube.
I also noticed the speaker has been repaired many times,so I may need a different speaker.
Anyone have a model H speker laying around that they don't need?
Very interesting forum.
I could read these posts for hours.
Thanks for your help,
Murf
Hi and welcome to the Phourm!
The easiest way to fuse it would be to connect in series with the cord going into the set. .75 amp should work fine and give you some protection. As for the speaker if you are clever you may be able to recone the one you have. There are lots of cones on that auction site. I'm getting a few for a model 20/21 speaker which I'm going to give it a try.
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
There are currently 856 online users. [Complete List]
» 1 Member(s) | 855 Guest(s)
