Long 41-255 Story Review
Thank you Terry, replacing the capacitor did the job Icon_biggrin . I would never have figure it out on my own. I'm only a beginner but learning new things everyday. I purchase a 47-205, the outside is not bad maybe a little cleaning and some dark wax to shine it up. Needs a recap job and hopefully that will get it going. Has anyone ever try to clean those dial lenses with plastic polish, mine is yellow Icon_confused: Thanks again, Mark.
Glad to help!
As to the lens.. I have had fair luck polishing some yellowed lenses with toothpaste. Moisten a soft cloth and put a small amount of toothpaste on and rub gently in a circular motion like you would when polishing a car. It will not remove yellowing that goes through the plastic but surface scratches and yellowing can be removed.
Kind regards,
Bob; I think that the Phillips was actually manufactured in Canada, though they may have imported many of the compone...Arran — 02:28 PM
I've started replacing the electrolytic caps now. As Arran mentioned, they are housed under a metal strap. Here's a ph...klondike98 — 12:22 PM
Thank for that info Arran! Very interesting. Phillips and Motorola must have made some type of marketing deal back then....klondike98 — 11:49 AM
46-1213 Schematic Question
Good idea on the fuse. These old transformers need extra protection.RodB — 10:02 AM
Hello Larry, Well, anyway I can contest about noisey grounds in my living room when I am using one outlet in my house a...radiorich — 08:03 AM
RodB & MrFixr55, Thank you both for the great replies at my questions, I appreciate the help very much.  As suggest...MissouriLarry — 07:04 AM
Rogers Majestic R-646
Vlad; I also have an R-646 but it's in rough shape, the chassis is complete, but the speaker is missing, and the cabin...Arran — 01:06 AM
Hi Larry, Back when this set was built, they did not use polarized power plugs. Technically, your chassis is sittin...MrFixr55 — 12:11 AM
Vlad, rather cool radio and for $18, I would have driven much more than 16t minutes or miles.! It does appear to be a T...MrFixr55 — 11:52 PM
I found this radio on my local Facebook a few weeks ago. The original price was 80CAD (about $57USD). Today I looked at ...Vlad95 — 10:32 PM
There are currently 1251 online users. [Complete List]
» 2 Member(s) | 1249 Guest(s)
