Modern speaker for bench tests?
I apologize if this is a repeat post, I've done a search and haven't found a thread on this topic.
My question is: can a modern speaker be used to bench test one of our old chassis? I read in a post that the original speakers have high impedance and I know that mondern speakers are only 3-8 ohms, so I'm guessing no, at least not without significant modification...but I thought I'd ask the question.
And a follow-up, if not, what is the recommended source for a test speaker? buy an old radio beyond repair or are there new-old style speakers available?
Dave C
If you are going to spend a dollar or two pick a signal tracer. Most will have place to connect your tube type output stage to it.
I use two bench speakers. For the early high impedance radios I use an Atwater Kent Model E2 but any of the E series works well. You can get one these, or the RCA's (Model 100?) for $50 or less. On the end of the speaker lead I've soldered a few feet of modern flexible wire with one inch pieces of large gauge bus wire that connect to the radio.
For the low impedance speaker I use a generic wide range 8" PM type. Mounted on this speaker is a generic 8 henry choke and a push-pull audio transformer. The interconnections between these are done with Anderson Power Pole connectors; they make it very simple to configure the radio output connections. For the connections to the radio I simply use clip leads with insulating hoods or tack solder.
The push-pull transformer allows me to make connections for single or push-pull outputs. For single ended I simply do not connect one side of the input. Some techies will scream "mismatch", and "Danger, Will Robinson!" but this application is for short term use and fine for the bench.
Pete AI2V
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
There are currently 1322 online users. [Complete List]
» 1 Member(s) | 1321 Guest(s)
