Philco 97
Have started the resto. Cabinet solid, finish shot. Speaker cone needed repair. Knobs, escutchion should respond to being cleaned and polished. Chassis appears to have a replacement power transformer and replacement on/off control. Also has a phones jack installed directly below the electrolytics. Note the number "97" on the back of the tuning condenser.
http://s1194.photobucket.com/albums/aa37...ilco%2097/
So far have replaced the 8mFd and 12mFd electrolytics, the 1,2,2 mFd electrolytic mounted under the chassis, the 0.001mFd between both plates of the 42 pp output, and the power cord. Tubes were tested, 6A7 was bad, 85 was bad, and one of the 78s was dead!! Both 42s were good and very close to the same reading!
When powered up, the radio works. However, the sound quality deteriorates after the radio has been on for a few minutes. I switched it off, let it cool off, and turned it on again. Same thing, sounds good, then starts to deteriorate after a few minutes.
Plan to start the cabinet tomorrow.
That's a great find, Tom, and good luck with the restoration!
Vlad; Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp o...Arran — 11:18 PM
Rod; I that 27 pf 1 kv capacitor you found a C0G ceramic cap or just a regular ceramic cap? A different topic but I t...Arran — 11:16 PM
Rogers Majestic R-646
Vlad; It's possible that the tar/bitumen using to pot the box may have lead to the failure of the transformer, either...Arran — 10:28 PM
Hi OSanders. another thing about the loop antenna is that it is directional. Try turning the radio in different direct...MrFixr55 — 09:19 PM
The 630v caps will do just fine. Physical size increases with capacity values and voltage. You don't have to replace 200...RodB — 09:09 PM
Help with Supreme 599
Good catch. The 589 is a better schematic but i dont understand how the voltage goes thru the meter to adj the line volt...daveone23 — 08:17 PM
Arron, Yes, I can see the differences in the interior design, but if you compare the schematics, they look very similar...Vlad95 — 06:57 PM
I am not sure how the loop antenna supposed to work but think I have figured it out. I had one lead on terminal 1 and go...osanders0311 — 06:56 PM
Thx Vlad.klondike98 — 06:54 PM
Hi Arran. I continue to disassemble and I see that the interstage transformer is completely beyond repair. It is placed...Vlad95 — 06:50 PM
There are currently 225 online users. [Complete List]
» 1 Member(s) | 224 Guest(s)
