reliability of mica caps
I am getting varying opinions about replacing mica caps on 40-180. What is the concensus here?
Thanks Jun
Referring to the Rider schematic, I would replace capacitors numbered 22, 23 and 24. The 370 pf caps usually have drifted and cause difficulty setting the pushbuttons and also may cause drift during warmup. The 250 pf cap was bad in a restoration that I did a while back. The oscillator was stopping intermittently.
Kind regards,
I decided to replace all the caps. Cost little over $13. Might as well.
Jun
There are currently 1107 online users. [Complete List]
» 1 Member(s) | 1106 Guest(s)
