Correct Pushbuttons and Grille Cloth for 40-185 console
Several months ago I purchased a 40-185 console in almost mint condition from a consignment antique store. I plan to clean up the chassis, recap it, replace the missing pushbuttons, and polish up the finish on the cabinet. I have two questions I need to have answered before I get too far into the restoration project.
Radio Daze has two versions of the octagon buttons used on the 40-185. One set is brown, and the other is rose-colored. Since my old console has no buttons at all, I can't determine which buttons are correct for this model. In addition, the original grille cloth has been removed and replaced by some hideous floral material that looks like it should have been used to upholster a sofa.
If anyone is familiar with the item numbers used by Radio Daze, could you please advise me as to which pushbutton and grille cloth designs are correct for a 40-185.
Thanks!
Mike Harmon, WB0LDJ
mharmon at att dot net
Mike - Welcome!
1940 Philcos such as yours used the translucent red (wine) pushbuttons. The brown buttons are used in 1941 Philco sets.
The correct grillecloth is the Philco "Large Diamond" pattern, #27 from Radio Grille Cloth Headquarters.
http://www.grillecloth.com/
Get it while you can...supplies are limited.
Rogers Majestic R-646
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 1010 online users. [Complete List]
» 3 Member(s) | 1007 Guest(s)
