Mystery Control Dial Warping: Can it be corrected?
I recently obtained a Mystery Control on FleaBay for $20 and it is in pretty good shape, other than the dial is moderately warped (about 3mm out of true) and it drags on the trim ring. Is there any ultra-spiffy way (or even better, a simple way) to correct the warping? Catalin is such fun... Icon_biggrin
Also, does anyone happen to know the correct size and thickness of the eight rubber washers that hold the rotary dial mechanism in position beneath the square brass nuts? These have, quite naturally, turned to stone (and in any case, I'm missing one of the square nuts and two washers).
(As an aside, I hope someday to obtain a radio that responds to this marvel of modern technology, but even if I don't it's one heck of a conversation piece on my coffee table!)
Check Out Chuck Schwarks Philco repair bench site. He has step by step instructions on how to fix a warped control. You can find the site listed in the parts resources page on this site. Good luck!
Kevin
The page is actually on this site.
http://www.philcoradio.com/tech/myscon.htm
Thanks, Ron! I knew I'd seen it somewhere.
I've been trying to explain the Mystery Control to my colleagues at work. Needless to say, I've been greeted with skepticism. I'm going to have to bring my trusty copy of "Philco Radio 1928-1942" with the copious illustrations to prove it... Icon_wink
An attempt to remove the Field Coil from a G speaker
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
Mike, This is just a thought, the are on the coil where the verdigris (green oxidation is) I wonder if that is where ...Arran — 06:32 PM
Mike; I've made a one or two spiders by using some card stock, and a razor blade, it took more then one try but they ...Arran — 05:48 PM
Philco 91 Restore Code ??
I wondered about that. Wish there was some place local to get this stuff.dconant — 04:20 PM
Philco 89 indicator light.
Bending the lamp bracket (moving the lamp, that is) can possibly change the shape of the pointer a bit, but not its loca...morzh — 04:01 PM
Because the usable power rating of it then is (3,200/20,000)*25W= 4W. Maybe a tad more due to the mass, but not much. Yo...morzh — 03:59 PM
Thank you Dan, that was the trick. I kept trying to rebend the lamp bracket but that wasn't doing anything to help.Jim Dutridge — 02:18 PM
20K 25 watt. I thought it was a 20 watt at first.dconant — 01:37 PM
My Philco 37-116 Restore
Nah, too much and not that important.morzh — 01:33 PM
There are currently 5643 online users. [Complete List]
» 1 Member(s) | 5642 Guest(s)
