41-608 Record Changer Issues
My BOL changer (Webster 23) has a rubber/metal riveted disc that transfers power from the motor shaft to the phono shaft that turns the gears. The rubber is shot and I cannot figure out how to get these two parts to meet. Has anyone run into this before and if so any suggestions? It is a very strange rubber/metal/rubber disc. All suggestions appreciated.
David,
Those are the idler wheels and there should be 2 of them on that changer. You might be able to resurface them or you can send them off to be rebuilt. West Tech services does this.
Sean
WØKPX
Rogers Majestic R-646
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 932 online users. [Complete List]
» 3 Member(s) | 929 Guest(s)
