cap question
I want to restuff a metal cap (non elec) it is a .50uf. The only cap I have close is a fat .47uf which will not fit inside the metal housing. Could I use two 1.0uf caps in series, or 2 .44uf caps in parallel? Im not sure what that does to the voltage value. The 1.0uf caps are only 400v, and the .22uf caps are 630v.
-Keith
Two 1mFd caps in series would be 0.5 mfd, if it would fit....
Seems like I saw 0.5mFd electrolytics somewhere, they should be small enough to work in the can....
Here is a link to a site that sells .47mFd electrolytics, but they are radial lead, not axial.
http://www.sterenshopusa.com/catalog/sea...CAPACITORS
Two .22 caps would be fine. Still 630V.
Sorry I wasn't clear the cap I'm trying to restuff is non-electrolytic. If I could parallel two .22 caps and get .44 and keep the voltage at 630V i'll go that route. Should be close enough to .50uf to work right?
-Keith
Yes, that will work just fine.
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
From what I see is the blue cap was added by someone after the radio was sold presumably to replace cap 40A. I can't tel...RodB — 03:12 PM
Correction My original picture shows #40 cap, blue cap and #42 resistor connected.osanders0311 — 02:23 PM
Well guys I am stuck, frustrated and about ready to give up. For starters all I'm getting from the speaker is a humming ...osanders0311 — 02:17 PM
[split] New member...
Thanks.  I'll try that.HowardWoodard — 01:13 PM
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
