Tuning Cap protection
I'm cleaning up and derusting the tuning cap on my 71. Once all the rust is gone and it clean is spraying it with clear lacquer to protect it from rusting again ok to do?
-Keith
I wouldn't do it lest you get some inside the plates. No problem brushing some laquer clear or silver color on the frame but be careful.
I would not, because you may effect the capacitance of the sections and effect alignment and tracking.
Getting it on/in the trimmer sections is a big no-no.
Unless you are storing this set in a high humidity and wide temp range loaction, once cleaned I would just take q-tips with Deix-it and lightly wipe down the stator and rotor plates with light film. DO NOT DO THIS IN THE TRIMMERS.
Deox-it leaves a non-corroding film behind when it evaporates.
Chuck
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
There are currently 559 online users. [Complete List]
» 2 Member(s) | 557 Guest(s)
