40-180 buttons needed
Hi all,
I'm working (slowly and painfully) on my first radio repair. I need a set of the channel pre-set buttons for a Philco 40-180. Are these readily available? If so, where would I look? Also, what is that big muffler-looking piece that sets at the bottom of the console?
Ryan
For the pushbuttons try Radio Daze. I just bought a set of the PB-PHIL41-W from them for my 40-150, which uses pretty much the same chassis as your 40-180. The muffler looking thing is the loop antenna.
Sean
WØKPX
Hi Ryan,
I bought a couple of sets of Philco pushbuttons from Antique Radio Knobs and they are very good quality:
http://www.antiqueradioknobs.com/index.html
I'm not familiar with your radio, but the thing that looks like a muffler may be the loop antenna assy., item 1 on the parts list.
http://www.nostalgiaair.org/PagesByModel...013336.pdf
There is 1 up for sale on Ebay:
http://cgi.ebay.com/170016359919
Carl
Northern Panhandle, WV
Yes, that's the piece I was talking about. One end is held on just by a staple or two. How solid do they need to be to be effective?
Ryan
Hi,
I bought a set from Larry at oldradioknobs a few years ago, and they are top quality. I think they are still only $15 a set. Use the wine colored ones for your set.
I looked at the link for the antenna assembly, and it had been relisted. However, it forwarded me to a Sony TV.
There really ssin't much holding them together, just be careful with it. Unlike the GE sets with the Super Beam-a-Scope, these need to be adjusted by hand.
Good luck on your set, I love my 40-180, it was my first console.
Gary.
Thx Richard. Arran, the 0.02 caps in mine are also 100v. As I mentioned the original paper tube is just a little small...klondike98 — 01:02 PM
New find. 91X code 225
Nice job there. A very distinguished looking radio. Would like to see a photo when done with added light. Paul B.Paul Philco322 — 12:27 PM
Thanks all. Yeah, I was motivated to do this one and they're generally easy to work on. I don't do a lot of early-'30s...pdieten — 10:22 AM
Hello Bob, What nice looking set it looks like a Emerson that I have you did great job with the two Electrolytic cans ....radiorich — 02:04 AM
Hello Paul, Well, done it looks great ! Sincerely Richardradiorich — 01:55 AM
Congratulations, Paul! That was quick...you made short order of that chassis restoration! And no coils to rewind...bonus...NostalgiaRadioTime — 01:07 AM
Bob; I was thinking the same with that 150 ohm resistor, put a larger value replacement in it's place to compensate f...Arran — 01:02 AM
And the chassis is all done, all caps and bad lamp wiring replaced, power switch repaired and in place, dial string tune...pdieten — 12:37 AM
As I think more about that 150 ohm resistor that directly follows the selenium diode, I’m going to have to add some seri...klondike98 — 11:47 PM
It looks like all the resistors except one are OK. Arran mentioned replacing the sand 150 ohm resistor and mine looks l...klondike98 — 02:25 PM
There are currently 1216 online users. [Complete List]
» 1 Member(s) | 1215 Guest(s)
