Restoring 38-7CS cabinet
I am restoring a 38-7CS for a customer, will use Mohawk aniline lacquer and their Finishers Choice Satin. This is my first experience with a radio!!
Questions:
1. Choice of stripper? The veneer is in good shape, but I know strippers can raise it. Lacquer thinner and then wash with denatured alcohol is my usual approach.
2. Should I apply a thin (1#) coat of dewaxed shellac to pop the grain prior to the med. brown walnut aniline. I usually use shellac in my restoration/new furniture business.
3. Very important! How to protect the "PHILCO" painted logo? I can mask around it with blue tape, is there any better way?
4. I plan on removing the radio from the cabinet to make the cabinet restoration process easier. Is this the usual practice?
Any and all insights/ suggestions will be greatly appreciated!
Thank you all.
Pete
I used Zinsser Citrus Action Gel on mine followed by Zinsser after wash. No issues with any grain raising. Then, I used Constantine walnut wood filler followed by Deft lacquer sanding sealer. Finally, Mohawk toner lacquer and Deft clear gloss lacquer.
It's all detailed in this thread: http://www.philcoradio.com/phorum/showth...p?tid=3653
Good luck
Thanks!
Your work looks great, I will study it and ask questions in the near future.
You say you "use Z. citrus action gel, followed by Zinnser after wash". Do you mean you use a Z. wash product or a Z. dewaxed shellac?
Pete
I think Bob is referring to Zinsser Magic Strip Citrus Action Gel, followed by Zinsser Stripper Wash.
Citrus Action Gel: http://www.rustoleum.com/CBGProduct.asp?pid=232
Stripper Wash: http://www.rustoleum.com/CBGProduct.asp?pid=239
If I am wrong, I am sure Bob will correct me. Icon_smile
Bob is another of our Phorum members who does excellent restoration work, and his YouTube videos have been a great help to many. Icon_thumbup
http://www.youtube.com/user/bandersentv
Yes Ron, that's exactly what I was referring too and thanks for the plug Icon_smile
To All,
I bought a knob from Mike Koste, purchased Mohawk lacquer toner/clear finish from a local Mohawk distributer (about 45 mins drive, 7.11/can).
Questions-not my last!-
1. again what is the preferred way to protect the "PHILCO" logo?
2. any tricks to disassembling the electronics and speaker from the cabinet? I haven't even looked under there except to verify that it is a 38-7CS.
I really appreciate the knowledge and the willingness of the phorum members to share!
Pete
you can get replacement decals from antique electronic supply ( http://www.tubesandmore.com )
p/n S-M907 $5.95 it should have the correct sized 'PHILCO' for your Philco
John
Las Vegas, NV USA
That will work if I screw up the original!
Thanks.
I am amazed at the resources available for this old radio.
Pete
peterc Wrote:2. any tricks to disassembling the electronics and speaker from the cabinet? I haven't even looked under there except to verify that it is a 38-7CS.
As I recall there are four small bolts holding the speaker on. Remove the nuts from the back while being careful not to damage the speaker cone. The chassis is mounted at a right angle and bolted to the underside of the top. I used a rachet wrench with extension to get up in there.
Good luck.
Thanks!
Show us some pictures please! thanks Doug Icon_smile
An attempt to remove the Field Coil from a G speaker
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
Mike, This is just a thought, the are on the coil where the verdigris (green oxidation is) I wonder if that is where ...Arran — 06:32 PM
Mike; I've made a one or two spiders by using some card stock, and a razor blade, it took more then one try but they ...Arran — 05:48 PM
Philco 91 Restore Code ??
I wondered about that. Wish there was some place local to get this stuff.dconant — 04:20 PM
Philco 89 indicator light.
Bending the lamp bracket (moving the lamp, that is) can possibly change the shape of the pointer a bit, but not its loca...morzh — 04:01 PM
Because the usable power rating of it then is (3,200/20,000)*25W= 4W. Maybe a tad more due to the mass, but not much. Yo...morzh — 03:59 PM
Thank you Dan, that was the trick. I kept trying to rebend the lamp bracket but that wasn't doing anything to help.Jim Dutridge — 02:18 PM
20K 25 watt. I thought it was a 20 watt at first.dconant — 01:37 PM
My Philco 37-116 Restore
Nah, too much and not that important.morzh — 01:33 PM
There are currently 6649 online users. [Complete List]
» 1 Member(s) | 6648 Guest(s)
