need help with my philcl 42-1013
My phono works great. No radio at all I used to have am and fm intermittently but I used it a little too much before I started to recap it. now I have no reception at all . i have resisters ordered too. Could someone point me in the right direction.the only electrolitic caps I haven't replaced yet are the two 8 mfd caps mounted on the chassis .those are coming could the if transformers be blown or what. I really don't know what to do next
Certainly no expert but if the phono works, the power supply is working. Still FIRST, replace those two electrolytic caps. I suspect it won't fix your problem but really needs to be done before they go out and take something really expensive. Then look at the schematic and find what tubes are common to the AM and FM, check them. Then, slowly go through replacing the wax caps. Double check those you have replaced to make certain the joints are solid and the values correct. It takes a little time but the AM and FM not working and the phono playing tells me you have at least the power supply working. Start with wax caps around the oscillator change a couple and try again. Keep it up through the RF amp (if it has one) Just go slow. Others here will help.
Jerry
magicclocks Wrote:My phono works great. No radio at all I used to have am and fm intermittently but I used it a little too much before I started to recap it. now I have no reception at all . i have resisters ordered too. Could someone point me in the right direction.the only electrolitic caps I haven't replaced yet are the two 8 mfd caps mounted on the chassis .those are coming could the if transformers be blown or what. I really don't know what to do next
I just finished one of these.
Some of those caps are a real bear to get to.
My radio had the 1012 chassis.Tranny was fried,so I found a cheap 1013 chassis and rebuilt that one.
My record changer need some work though.Beam of light changer.
Have fun with this project.
I have a few parts left with the 1012 chassis if you need anything.
murf
46-1213 Schematic Question
Hi Larry, Back when this set was built, they did not use polarized power plugs. Technically, your chassis is sittin...MrFixr55 — 12:11 AM
Rogers Majestic R-646
Vlad, rather cool radio and for $18, I would have driven much more than 16t minutes or miles.! It does appear to be a T...MrFixr55 — 11:52 PM
I found this radio on my local Facebook a few weeks ago. The original price was 80CAD (about $57USD). Today I looked at ...Vlad95 — 10:32 PM
New find. 91X code 225
Bragging about my latest find. I've been wanting one of these four-column jobs. Didn't expect that what landed in the ho...pdieten — 09:10 PM
You have to examine the connections to A and B to see which one matches the schematic. It appears there are two white wi...RodB — 07:39 PM
In the photo of my Chassis, I now have two wires marked "A" and "B", these are my power cord wires. ...MissouriLarry — 02:46 PM
Gary, Thanks for the reply!  I have no intention of introducing any electric to my radio until I recap it.  I just want...MissouriLarry — 02:14 PM
Hi Larry, Usually you'll want to attach the hot side of the power line cord to the power switch. That way when the s...RodB — 02:06 PM
1934 American Bosch 440T restore on YouTube
That's an interesting radio Buzz! Great first video also...Eliot Ness — 01:59 PM
Hello Larry. Replacement of the power cord is a priority, but not the first. All paper and electrolytic capacitors nee...GarySP — 01:36 PM
There are currently 524 online users. [Complete List]
» 1 Member(s) | 523 Guest(s)
