Philco 90 BC resistor question
Doe's any one know off hand what the wattage rating is for the BC resistor, part #5365 on a Philco 90?
at some point in my 90's life something happened that caused the resistor and several other block caps and resistors to overheat. although the BC resistor still reads the correct resistance for all three sections, the coating over the 180 ohm section has broken off so I am guessing that I should probably go ahead and replace it. Thanks!
Kevin
I don't know if that's necessary If the chassis is working properly the heating issue shouldn't be a problem. I had a problem with a model 20 where the heavy thread wound around the BC resistor had burned up/ flaked off. I would suspect that it is more of a protective coating so it won't be shorted out by coming in contact by other parts. You could probably rewind the thread over the resistor.
I'd say that your looking at a resistor that is 20-50wts.
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
