Philco 71 restoration
#31
Here is a couple pics of the coil rewind in case anyone wants to see what it looks like.
[Image: http://i1129.photobucket.com/albums/m501...G_2239.jpg]
Secondary half removed from coil form. Pay attention to the direction the coil is wound if its wound backwards it will not work (Thanks Terry).
[Image: http://i1129.photobucket.com/albums/m501...G_2241.jpg]
After removing the rest of the wire the secondary was rewound with 32ga magnet wire. I started from the top to the bottom as it was easier.
[Image: http://i1129.photobucket.com/albums/m501...G_2242.jpg]
Another view of the rewound coil. I soldered the ends to the lugs and then applyed Q-Dope to the coil to hold it in place.
Here is a neat video about transformer (coil) phasing. This guy has lots of neat videos about tube radios, and circuits.
http://www.youtube.com/user/AllAmericanF...RBqUQPLk-M
-Keith
#32
Well I got it playing pretty well, then I tore it apart to clean and derust the chassis.
I'm stuck on what to do with the large tube shield that mounts on the side of the chassis. It has a lot of rust on it, and the two paper labels are in really nice condition. I dont want to damage the labels with navel jelly or water durin the cleaning. any ideas how I could tackle this?
Pics:
Back of shield
[Image: http://i1129.photobucket.com/albums/m501...AG0783.jpg]
Side of shield
[Image: http://i1129.photobucket.com/albums/m501...AG0784.jpg]
-Keith
#33
Keep up the good work, Keith! You have done a super job resurrecting this set!
I know there is a fellow out there that does repop labels, I have seen them and they are pretty nice! I'll try to find who he is from a buddy who has used them and post it to this thread. That is, if you want to go that way. It will solve your dilemma about de rusting your shield.
#34
Here is a link to an eBay sale this guy has. At the bottom he lists the model Philcos that he makes labels for, and the 71 is listed there.
http://cgi.ebay.com/330561702779
#35
If you have a flatbed scanner you could make your own labels, even touch up the image where needed.
#36
Thanks guys. I think I'm going to try the guy on ebay and see how his labels are. I also need a set for a 60B I just bought.
-Keith
#37
Does anyone have the alignment instructions for the 71? Cant find it in all the documentation i cobbled together.
-Keith
#38
It's all done..
I made a video slideshow with some pics of the restoration process.
Philco 71 Restoration Slideshow
I post this before but I think it was lost in the Phorum move? I couldn't find it. Figured I put it here cause I like bragging Icon_angel
8)
-Keith
Model 96 cabinet veneer
I can't figure out what the first step is, let alone the final step. I have tried copying pictures from my hard drive a...TGLager — 01:40 PM
Philco 38-2 Low Volume
I managed to get some more time on this. Hi Mr. FixIT, The radio has been recapped. Many of the resistors were rep...dconant — 01:39 PM
Thanks guys for the help. I started looking at these points but I have to quit for the day. I will be looking into this ...dconant — 12:23 PM
RCA WV-98c
Check out this crazy zero pot operation. Touching it drives it crazy. Its rubber tipped. Also the 6al5 has no negative v...daveone23 — 12:08 PM
If you check all of that and still have a problem (my first inkling would be one of the 6F6s) then look at the 6J5 phase...RodB — 10:44 AM
RCA WV-98c
Those will probably depend on teh switch combination. Could you list some that you see, their values and what they sh...morzh — 10:26 AM
You are probably skipping the final step. Once you select the photos you want and they get downloaded, the system assign...RodB — 09:36 AM
RCA WV-98c
At this point, there is no input, just internal voltages Which are incorrect and not sure what they should be.daveone23 — 09:15 AM
Hi DConat, Generally, the lower the plate voltage the less negative the grid voltage has to be. Since the plates an...MrFixr55 — 09:27 PM
RCA WV-98c
If I had it in front of me, I would triy to trace the signal on one of the non-working functions. Try to trace and high...morzh — 08:21 PM
There are currently 1221 online users. [Complete List]
» 1 Member(s) | 1220 Guest(s)
