Phorum How-To #7: How Can I Change My Time Zone?
First, go to your User CP. Now, click or tap Edit Options under Your Profile.
[Image: https://philcoradio.com/images/phorum/Ph...07_001.jpg]
Look for the Date and Time Options section:
[Image: https://philcoradio.com/images/phorum/Ph...07_003.jpg]
Under "Date and Time Options," look for the text which reads "If you live in a time zone which differs to what this board is set at, you can select it from the list below."
The default time setting for the Phorum is US Eastern Time which is GMT -5:00.
To change it to your local time zone:
Click or tap the drop-down box labeled "GMT -5:00 (current time)" with a time setting, as shown below:
[Image: https://philcoradio.com/images/phorum/Ph...07_004.jpg]
From this drop-down box, select or tap the time zone where you live.
Hint - GMT -5:00 = Eastern Time Zone.
GMT -6:00 = Central Time Zone.
GMT -7:00 = Mountain Time Zone.
GMT -8:00 = Pacific Time Zone.
For Phorum members living outside the USA, you should be able to figure out the proper settings here.
Other Time Settings
While you are here, you can also change a few other settings if you wish to do so.
Date Format
If the date format is not to your liking, click or tap the drop-down box and change it from the system default to whatever you wish.
[Image: https://philcoradio.com/images/phorum/Ph...07_005.jpg]
Time Format
If the time format is not to your liking, click or tap the drop-down box and change it from the system default to whatever you wish.
[Image: https://philcoradio.com/images/phorum/Ph...07_006.jpg]
Finally, you may choose whether you want the system to compensate for Daylight Saving Time or not:
[Image: https://philcoradio.com/images/phorum/Ph...07_007.jpg]
Select or tap the DST setting you prefer in this drop-down box.
When you are finished, click or tap the "Update Options" button...and your settings will be saved.
Thanks, it worked
Joe
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:25 PM
Testin a speaker and output transformer Trutone A2-G
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:24 PM
Save the money on the Kapton tape. Just cut an insulator to size out of a clear plastic blister pack and attach it arou...GarySP — 01:13 PM
The thing is when I touch or probe the antenna terminal, the volume control input, the wiper (output), and the primary t...Stormlord5500 — 12:53 PM
Two small radios from France. Restoration and review.
Hello, Vlad. I agree with your description of French radios. I might add that they are made like French cars – extravaga...RadioSvit — 11:08 AM
I do thank you all for helping me out on this.Stormlord5500 — 08:01 AM
It does oscillate. Here's the deal. If I touch a probe or my finger to anything in the secondary circuit of the antenna ...Stormlord5500 — 08:00 AM
Hello Arran, Some great info so you are talking about silver migration then that seems to really play issues with these...radiorich — 02:43 AM
Hi Stormlord and welcome to the Phorum. I am scratching my head because, even if the primary of the antenna coil is b...MrFixr55 — 01:56 AM
You do not have to use Kapton: buy a bottle of fabric glue and simply put a thick layer to fix the turns.morzh — 04:04 PM
There are currently 2018 online users. [Complete List]
» 1 Member(s) | 2017 Guest(s)
