1935 model 18 trim color
I am about to restore a model 18 scalloped cathedral cabinet that has lost most of its original finish, in the pictures I have seen of the 18, 118, 144 the two lines/grooves under the bottom row of knobs look to be reflective in the photo. Does anyone know what color was used in these two trim lines?
Thanks, Todd
Light Tan.
(05-01-2012, 02:30 PM)TA Forbes Wrote:  Light Tan.
Rogers Majestic R-646
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1104 online users. [Complete List]
» 4 Member(s) | 1100 Guest(s)
AvatarAvatarAvatarAvatar
