What wood you do to this 39-45
The back 1/2 inch or so of the veneer is split off the top behind the door on the top. It's 2 pieces of 3 1/2" x 17 1/2" in a mirror image pattern. I'm thinking I would be better off replacing it with 1 7"x 17 1/2" sheet of straight/curly based in part on my lack of skill. And since it is disconnected and or above the surrounding woodwork, I wont have any matching problems per say. Icon_confused:
And how do you tell what kind of walnut it is? It is not carrying a birth certificate or passport. Icon_eek
John
Las Vegas, NV USA
In most cases they used some form of French walnut either straight or quarter sawn, sometimes they used stump or burl walnut but not usaully on a top I think that the best thing to do, if it's book matched, would be to cut a straight line parallel to the grain where the veneer splintered off and butt join a new strip (one with a similar colour and grain) along the back side. The Albert Constantine company has a gallery with photos of the various species of veneers they have available, it may help to identify what species was used in the top.
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
There are currently 1088 online users. [Complete List]
» 2 Member(s) | 1086 Guest(s)
