Bass fully to one end of range
Hi all,
I'm restoring a Philco 48-1263 radio/phono. I had no tone variance coming from the on-off/tone potentiometer and on closer looking found one end of the pot dead ended on a terminal strip. It seems a cap and resistor were flat out missing. I replaced the cap from the pot wire at the terminal strip to the #2 pin, the plate, on the 7C6 AF Amp tube. Now I have bass, but only crammed into a very short end of the tone range. 90% of the tone range is full treble, no variance.
Did I maybe wire this wrong? I have the schematic, but I'm not terribly proficient reading them.
Alan
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
There are currently 996 online users. [Complete List]
» 2 Member(s) | 994 Guest(s)
