D-10 phonograph problems
I know that this phorum is "Electronic Restoration" so I hope my mechanical problems are welcome here.
I'm working on a 48-1263 radio/phono and have the phono working quite well with a new cartridge and all cleaned and freshly oiled. But, I have a couple of mechanical problems that still have me stumped.
The racheting teeth mechanism in the trip function seems to need a spring with incredibly small tension. Any tension at all and it stops the tone arm movement. I've seen reference to this problem, but what have others used there? If I disconnect the spring all works fine except I’ve sacrificed the trip mechanism.
I have 10 inch records to play and the tone arm was dropping in location for 12 inch records. I found that by removing the arm that controls the record drop mechanism the arm dropped in the proper 10 inch position since now the arm controlling the tone arm drop position was able to travel fully to the little adjustable brass cam that fine tunes the drop position. The arm controlling the record drop mechanism has a sliding pin that was holding back the tone arm drop arm from reaching the little brass cam. Whew, I hope that there’s some clarity in that.
I would sure appreciate any wisdom that you could send my way. I got a new cartridge from everythingradio.com, it installed great and the player is working great with fantastic sound quality, except for the two mechanical problems.
Alan
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
There are currently 1122 online users. [Complete List]
» 1 Member(s) | 1121 Guest(s)
