philco 37-630 volumn issue
Hi:
Am working on a Philco 37-630. Having a problem with the volumn /reception level. The set has a medium to low volumn and limited reception. However when I touch the grid cap of the 6A8G tube (Det/Osc) the set blasts away to the point you have to lower the volumn control along wihch you have a selection of many more stations.
. I have replaced all caps in the set so that should not be an issue. I tried a different 6A8G tube no luck. Also this problem happens on both the broadcast and shortwave bands alike, so I am not inclined to think its a coil problem, unless both coil sets for each respective band are shot. Alignment of the set did help a little but not enough to maintain the high volumn that I know this set can achieve. When using the signal generator the tone would also come in moderate to low and when the grid cap was touched it would blast away!! Besides keeping my finger on the grip cap when playing the set any suggestions?? Thanks.
There is a good chance both ANT coils are open sue to age or static discharges in the past. Also be sure of the continuity thru the bandswitch contacts as well for the ANT coil switch circuit.
philco predicta
Hi CGL, Yes, troubleshoot the 140V Power supply, something is definitely loading it down, and since this supply excl...MrFixr55 — 07:32 AM
1934 American Bosch 440T restore on YouTube
Looking forward to Part 2.Jimradio — 07:30 AM
Yeah, looks really dense. It is amazing how many sets of brand A were made by Brand B. I have Mid 50s RCA that is an e...MrFixr55 — 10:15 PM
Philco 60 Power Trans
I am not 100% sure of the reason, likely due to the depth of the winding, but on HV windings of a power transformer and ...MrFixr55 — 10:04 PM
46-1213 Schematic Question
Hi Larry, Great idea on the fuse!  Place in the line at the power switch.  Best between the cord and switch.  While ...MrFixr55 — 09:59 PM
Philco 47-205
Just picked up the second of the three Leatherette Philco's. (My second one in the three-radio series) Nice shape, all p...slford310 — 09:18 PM
Dan; I take it that you mean that the H.V winding reads 157 ohms on one side of the center tap, and 177 ohms on the o...Arran — 07:00 PM
New find. 91X code 225
Hello, I have a Philco 91 code 121 (one speaker). I found more info here that might be of some help. Might want to fo...dconant — 06:42 PM
Hello, The HV winding on the trans is about 700 volts no load. My meter (Fluke 115) only reads to 650 volts so I meas...dconant — 04:18 PM
Thanks all. To be honest I don’t know what to make of it being in this cabinet style but I like it a lot. I specifically...pdieten — 12:47 PM
There are currently 1224 online users. [Complete List]
» 2 Member(s) | 1222 Guest(s)
