PHILCO 48-200 BAKELITE TUBE RADIO
Is this radio: PHILCO 48-200 BAKELITE TUBE RADIO, a good one?
Easy to work on; fix and restore?
Is it sort after by collectors?
Any help would be appreciated.
TommyR Icon_smile
All Philcos are good ones Icon_biggrin I have restored a couple of them and were not that hard for a beginner like me. They are fairly common I think but still a nice little radio. Do you have the brown or ivory version?
Chris
Chris Drumma Wrote:All Philcos are good ones Icon_biggrin I have restored a couple of them and were not that hard for a beginner like me. They are fairly common I think but still a nice little radio. Do you have the brown or ivory version?
Chris
Hi Chris:
It's a brown one. It's in excellent shape with the exception of a crack running along the top left of the case.
It was modified, the line cord looks new but very short (non polarized) and one side of the line is going to a 3ag fuse and power resistor, there is also a disc cap or mov across it. All this is placed on a small board affixed to the top of the case inside.
It plays good, although there are more stations coming in from mid to end of band then from the beginning to mid?
Very clean inside and out.
What do you think?
TommyR Icon_smile
Philco 60 Power Trans
Dan; I take it that you mean that the H.V winding reads 157 ohms on one side of the center tap, and 177 ohms on the o...Arran — 07:00 PM
New find. 91X code 225
Hello, I have a Philco 91 code 121 (one speaker). I found more info here that might be of some help. Might want to fo...dconant — 06:42 PM
Hello, The HV winding on the trans is about 700 volts no load. My meter (Fluke 115) only reads to 650 volts so I meas...dconant — 04:18 PM
Thanks all. To be honest I don’t know what to make of it being in this cabinet style but I like it a lot. I specifically...pdieten — 12:47 PM
Nice grab! It appears to be a 19X cabinet. This wasn't unusual. Philco often retrofitted to other cabinets as invento...GarySP — 12:32 PM
I would certainly write down step-by-step the progression of disassembly of the works, and probably cuss out the electri...GarySP — 12:18 PM
Nice looking! This annotated schematic from our library shows parts that are slightly different in the early and later ...klondike98 — 11:33 AM
LOL!! Well Arran, if you do dive into it and come across any advice on dealing with accessing components let me know. I...klondike98 — 11:56 PM
Bob and Gary; I have the further complication on the Phillips that they decided to use some 200 volt rated paper caps...Arran — 10:05 PM
Thx Arran & Gary. Yes its super crowded in the chassis and I've debated whether to try to restuff caps or not. I t...klondike98 — 07:40 PM
