Threads: 573
Anyone know where I can get me a trimmer adjuster, which is a 1/4" socket made out of plastic or some non-metal non-magnetic stuff?
Regular socket won't do, and I am trying to tune my Philco 80 backside trimmer caps.
City: Sedona, AZ/Placentia/CA
Morzh, I made mine and showed details in the first forum on Philco radio discussions. The last page I believe of my thread on my 111 rebuild. Seems to work.
Jerry
Threads: 92
City: Clayton, NC
Agree, will probably have to make one, or maybe luck out and find one where someone is selling old test equipment/tools.
Threads: 573
While I was waiting for answers, I simply took a 'large plastic wall anchor, heated it with a Milwaukee gun and stuck the appropriate size nut inside, and let it cool off. Then I used it as the socket.
Long term, I think I will trake a piece of plastick stick, will heat the same nut, and jam it in the end of it, and then will use that. May be drill a hole across and insert a metak rod to make it easier to rotate.
What I found, I was able top use my metal socket, but then I had to rotater and retract to see the real effect.
The rotate - retract was only needed at the high end of scale adjustment and IF adjustmentl at the low end of scale the effect did not change whether I kept the socket in or removed it.
It is doable, just not convenient.
Mortz, certainly more than one way to skin a cat.
Jerry
Threads: 573
Jerry
Can you give the link, I can't find it in that thread.
Here you go Morzh, this should go to page 2. It was part of my rambling on repair of my 111.
Jerry
http://philcoradio.com/phorum/showthread...078&page=2
(This post was last modified: 09-10-2012, 11:28 PM by
jerryhawthorne.)
Threads: 92
City: Clayton, NC
Yes, the metal driver will give a false reading until you pull it back out.
