philco 37-650 dial window and surround
trying to remove dial window and surround complete from 37-650 anyone removed this. i dont see anything but two tabs on the back and straightening them didnt help-------------- thanks
Turn the outer ring counter-clock wise and it will come apart. Be careful as the glass will fall out when you do this.
thanks. i will watch the glass
I'm going to try this on a 38-10F. It sounds like it's of simular construction. Thanks.
Yes, same thing. Good luck!
Rogers Majestic R-646
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 1122 online users. [Complete List]
» 1 Member(s) | 1121 Guest(s)
