Philco QC?
Working on a Philco 90 console and have a parts chassis. Just looking at them I can't help but notice what I think are crayon marks, yellow "V" and blue straight lines all around both chassis. One chassis on the outside and the other on the inside. Looks like marks perhaps made by QC checking various parts and signing off? Just wondering? You know inquiring minds?
Jerry
I'm sure those are contruction station marks, q/c and re-work markings, as well as final "ok". Since Philco used several outside cabinet shops, besides their in-house, cabinet marks will vary from jobbers. I know that the cabinet shop "number" was uaually in the cabinets too.
Ron has a listing of them here on his site.
I'm sure Ron and elucidate and or correct me. He is the Philco cabinet guru.
Chuck
Thanks Chuck. The markings I'm referring to are on the metal chassis. On one set they go around the outside, the other set in marked around the inside of the chassis.
Jerry
I've seen them anywhere on chassis and cabinet.
Yes, often QC marks, initials, stamps, etc... made on sets. Chalk marks in cabinets, etc. Initials, dates and stickers of repairmen of yore also common and should be preserved if possible, at least take a picture, print it and stuff it into the cabinet along with your notes if you care about those things surviving.
Some even put dots of paint on connections to signify inspection. Every Schulmerich amp and many altecs that I have worked on and other sets as well have those landmarks. You have to be very clever to hide a repair on some of these sets. Nail polish works for the dots, bare solder joints will tarnish in a year or so and match the others in a year or so, there are a million other things that can be done.
Philco 60 Squealing
Usually a wave trap is for keeping IF signals from entering the antenna and from leaving the antenna. You feed an IF sig...RodB — 09:30 PM
Philco 60 Squealing
I just peaked it for the best signal at 600. NULL it for IF frequency, originally it would have been null for 500kh...Chas — 08:05 PM
Philco 60 Squealing
Wavetrap no longer matters.morzh — 05:19 PM
Philco 60 Squealing
Rod, I had checked out your suggestions but did not help. I did solder the ground rivets to the chassis as Chas suggeste...dconant — 04:52 PM
37-690 Bass Choke Replacement
Yeah, I know, Mouser and Digikey don't have "big iron" components. For some reason Philco was messing with the...Radiodial — 04:25 PM
Yes, I just had to deal with that while repairing the 37-604 Philco. Exactly that value choke was gone. And the current ...morzh — 03:52 PM
Ah, now where to find one. I've into this before on smaller sets, I now recall. Hammond makes one that is only rated...Radiodial — 03:27 PM
Philco 38-7 Speaker
Ask the admins to put them together. As for the renaming, while inside the thread, you simply press "New reply&quo...morzh — 02:23 PM
This is the parts catalog. 32-7528 choke is 65H, 10mA, 2,250 Ohm inductance. Find a suitable one.morzh — 02:18 PM
While troubleshooting the no bass amplification issue, I think I found the culprit. The choke #104 is reading 164K ohms....Radiodial — 01:42 PM
There are currently 3775 online users. [Complete List]
» 1 Member(s) | 3774 Guest(s)
