Not sure what i have...HELP??
Can someone tell me how to find out info about a set i have...it is a philco console, but i can't find a pic like it on here. the face of the radio is on the upper front, has wooden buttons for selction, but also has 4 large dials on either side of the face. Has several different countries listed on the face/...along with AM and aircraft and several more..don't remember the others and i am not where it is at the moment...if someone could point me in the right direction i would be most thankful
Deb (sorry don't have a pic at the moment)
Hi Deb and Welcome to the Phourm!!!
Without a pic it going to be tough! You maybe able to find a small blue and white sticker on the inside of the cabinet that will display the model number. It may also be stamped in ink on the chassis. Most of the time it will be two digits a dash and one-three more digits. The first two will be the year it was made. Did you have a look in the Gallery??
Thanks Terry, i kept looking thru the gallery and think i found one that is pretty close...It looks like the 40-215RX only the buttons are closer together and are wooden
Philco never used wood push buttons. They where tenite which is an early type of plastic. Not known for it's longevity most have badly deteriorated by now. Replacements are available. Maybe someone hand carved wooden replacements?
Hello, Deb: try to get a pic to post here on the Phorum, that would be a major help in pin-pointing what you have.
She figured out at it's a 41-295. Now she try to find it's worth. I gave a few ideas...
Zehr gut!!!
[split] New member...
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
