38-15 Cabinet restored
My 38-15 project is almost complete. Here is a couple before and after pics of the cabinet. Grill cloth isn't correct but it'll have to do at least its a Philco pattern.
Before:
[Image: http://i1129.photobucket.com/albums/m501...99f9c2.jpg]
After:
[Image: http://i1129.photobucket.com/albums/m501...5A8A44.jpg]
-Keith
Nice work, Keith! Icon_thumbupIcon_thumbup
Ditto! Icon_thumbup Icon_thumbup
Very niceIcon_thumbupIcon_thumbupIcon_thumbup
M R Radios   C M Tubes
Looks almost new!!!! As it should. Great job.
Thanks for the comments. It still has spots and a few dents in the wood I didn't want it up look factory new. I was able to remove or improve a few deep dents with a hot clothes iron.
I finished it up last night.
Link to the final pictures of the 38-15:
http://philcoradio.com/phorum/showthread.php?tid=5543
-Keith
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 968 online users. [Complete List]
» 1 Member(s) | 967 Guest(s)
