Philco 49-1606 AM/FM/phono console
I found this Philco 49-1606 AM/FM/record player console buried in a pile of stuff at a closed TV shop and was able to buy it for a reasonable price.
The main thing that attracted me to this model was the dual tonearm record changer. One tonearm plays 78's and the lighter tonearm plays LP's. I wish it would play 45's; but, it will be easy enough to use a Y-adapter and plug in one of those RCA 45 rpm attachments.
I've not done anything, other than examine the inside of the radio. It is a power transformer-less set that uses two selenium rectifiers in a voltage doubler configuration.
I figure this will be a decent performing unit once I get it restored.
[Image: http://i538.photobucket.com/albums/ff341...c50ea9.jpg]
[Image: http://i538.photobucket.com/albums/ff341...03527a.jpg]
It's a cool modern look. The book matched mahogany crotch veneer is striking.
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
There are currently 1065 online users. [Complete List]
» 2 Member(s) | 1063 Guest(s)
