Philco 630 console question
On the back of the chassis, there is a 2-screw terminal strip. The wires go up to the band switch. The band switch is 3 position; AM and two SW. If these 2 screws are for a phono, is something missing.
Those screws are for the lead-in of the Philco High Efficiency Aerial.
These sets were designed so that you could use Philco's special all-wave antenna without an external coupler. If you wanted to use a conventional longwire, you connect it to the ANT terminal as was the practice in most 1928-1935 Philco sets.
Thanks. After studying the schematic further, these, I believe, are identified as BLACK and RED. I've now got bigger problems. The last guy did a lot of major changing and I believe I know why. There's nothing going to the plate of the RF 78 tube. And the antenna wire goes straight to where that plate wire went. After further metering, it appears that a section of the RF transformer is open. I gather that this not good?
So, I like new challenges.....is repairing a section of the RF transformer something that I can handle?
Nope, not good.
I suggest finding a 620 or 630 for parts, and install the good RF coil from the donor to your 630.
An RF coil from a 620, 625, 630 or 635 will work.
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
There are currently 696 online users. [Complete List]
» 2 Member(s) | 694 Guest(s)
