38-17F
Does that thing have any photofinish on it??
Tnx
38-18??? Do you mean perhaps the 38-17 you recently purchased?
If so, then yes, I seem to recall that the front panel of the set does indeed have photofinish; the rest of the set does not, I think.
Yup that's what I meant. Your a mind reader! Tnx I thought I'd ask before I started with the stripper.
I updated the title of this thread to avoid confusion. Icon_smile
I suggest you check and see if the front panel is held in with screws; if so, it might come out easily if you remove the screws. If it does, then you could feel free to use your favorite stripping chemical(s) on the body of the cabinet while you store the front panel away safely somewhere else.
Rogers Majestic R-646
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
