Mystery Model from Canada
I am so glad to have found this forum. Our Philco console radio has been in our family for nearly fifty years. I can't find any good info for it. It was produced in Canada (not sure which year) and the manual I have for it is for model 726. It has a five tube am radio and a three speed turntable. The chassis number stamped on the back of the tuner is 726-2. The cabinet is identical to a 1950 50-1721. The radio and turntable still work and the cabinet is in very good condition. Can anyone point me in the right direction to snag someone info?
You probably already read Ron's info at http://www.philcoradio.com/world/canada.htm
Others in this phorum may have additional info but I did find this-- model was listed for sale in Oct 2010 for $100 at http://brantford.canadianlisted.com/art-...59416.html
You might also get in touch with the JustRadios folks and see if they have a schematic or other info: http://www.justradios.com/schematics.html or get some info/schematic from the Canadian Vintage RAdio Society http://wakefieldwebworks.ca/cvrs/resourc...c-service/
I couldn't find anything about it on the philco Canada website you mentioned above. I will certainly check the other websites you have suggested.
Thanks for the reply Bob.
Cheers
37-60 revision 6
Shadow Meter Bulb
Hickok AC51 tube tester
Model 28L
Hello, I'm restoring a Philco 28L and the output transformer is open. Part number of the transformer is 32-7020. Can...HORSTE — 10:32 AM
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
There are currently 6110 online users. [Complete List]
» 1 Member(s) | 6109 Guest(s)
