Philco 53-954
Hi, I have a Philco 53-954 with a 6AQ6 tube. My schematic shows info for the 954 & 950. The 950 shows it using a 6AQ5. What is the correct tube for my 53-954 ??? Also, the radio plays very well for 10 minutes then it goes nuts with noise. The station is still strong, but the crackling noise is not normal. I can't find what is causing this problem. I hope you can help !! THANK YOU VERY MUCH !!!!!!!!!!!!!!!!!!!
Joe
Hi Joe and Welcome!!
Looks like it's a 35C5. The 6AQ5 heater current is much higher than the others with these series strung set they need to be the same. If you pop a 35C5 in it you can't hurt it. The 6AQ5 will be a problem and burn out other tubes. As for the noise sounds like you need some new caps or you've got a bad IF can.
GL
Looking at the Rider ( http://www.nostalgiaair.org/Resources/784/M0013784.htm )info I think the 6AQ5 label is a typo. That label shows up on the views for parts locations but on the actual wiring schematic it shows a 6AQ6. A 6AQ6 is a twin diode-Hi mu triode while a 6AQ5 is a beam power pentode. The schematic is wired for the twin diode 6AQ6. You can check these tubes out at http://www.nj7p.org/Tube.php
As for the noise--have you changed out all the capacitors?
Terry I think its the detector tube rather than the output tube that's in question unless I misunderstood what Joe was asking. Joe?
THANK YOU VERY MUCH for your help !!! I put in a 35C5 and AM reception was weak/poor. I put the 6AQ6 back & reception was superb. I still get the crackling noise. I did replace all caps & electrolytics. Anything else I should try ??? THANKS !!!! Joe
If the pin out is the same you could drop in a 12AT6 or 12AV6. I didn't look at the pin out
46-1213 Schematic Question
In the photo of my Chassis, I now have two wires marked "A" and "B", these are my power cord wires. ...MissouriLarry — 02:46 PM
Gary, Thanks for the reply!  I have no intention of introducing any electric to my radio until I recap it.  I just want...MissouriLarry — 02:14 PM
Hi Larry, Usually you'll want to attach the hot side of the power line cord to the power switch. That way when the s...RodB — 02:06 PM
1934 American Bosch 440T restore on YouTube
That's an interesting radio Buzz! Great first video also...Eliot Ness — 01:59 PM
Hello Larry. Replacement of the power cord is a priority, but not the first. All paper and electrolytic capacitors nee...GarySP — 01:36 PM
Ok, now is time to post my first question.  I have a Philco 46-1213 that I am going to start working on here real shortl...MissouriLarry — 12:48 PM
Well, never enough yet how much is too much? I ordered some spare parts from a couple vendors in China and now have ship...TV MAN — 10:49 AM
A Marconi model 86
This Marconi was a bit of a challenge. It was totally missing one electrolytic  capacitor, and the photos show a couple ...Dan Walker — 10:48 AM
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
There are currently 522 online users. [Complete List]
» 2 Member(s) | 520 Guest(s)
