Four tube Philco console?
Did Philco ever make a console version of one of their four tube sets like the 37-84? For some reason I keep picture in my mind that I once saw a Philco console with a similar dial set-up to my 37-84. Could be my mind is playing tricks on me though. Icon_crazy
You may be thinking of the 37-33F, which only has two knobs and a dial like a 37-84, but is battery operated. There is also the 37-33B cathedral, which looks identical to a 37-84 but, again, is battery operated.
http://www.philcoradio.com/gallery/1937a.htm#b
The 37-33 is a good little battery set. I have it in a BG cab. Built a p/s a few year ago. It uses something like a 1E7 as the audio output it's a dual power pentode wired in p/p and real rattle the 8" spker.
That's what I recall seeing! Didn't think Ohio's gloomy weather had totally rotted my brain yet. Good reference of the dial on the 37-33B above it. I THINK that is the type dial I need for my 37-84.
[split] New member...
Thanks.  I'll try that.HowardWoodard — 01:13 PM
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
There are currently 1321 online users. [Complete List]
» 1 Member(s) | 1320 Guest(s)
